bushings and struts
do the stock bushings work with the eibach lowering springs. and would the stock struts work to
RE: bushings and struts
ORIGINAL: 2000_BLACK_SS do the stock bushings work with the eibach lowering springs. and would the stock struts work to yes, they should |
i have never heard of bushing issues when changing springs. so i would say your fine. dont see how a spring could effect the bushings... but oh well....
as for the stock struts.... that is a diff story. i have heard people talk about a "pogo" effect cause by using stock struts with eibachs or any other lowing spring for that matter. the strut of choice is a kyb gr2 or better. if your in a pinch and dont have the $$$ yeah the stock struts will mount up and fit. but if the idea of geting your springs was for performance.... your better off doing it right and save for the struts. that way you are installing them together and not having to redo it |
