-   Tires/Rims/Suspension (https://montecarloforum.com/forum/tires-rims-suspension-16/)
-   -   Bolt pattern (https://montecarloforum.com/forum/tires-rims-suspension-16/bolt-pattern-12642/)
05_monte Mar 17, 2009 07:17 PM
Bolt pattern
Hey i have an 05 monte and i know the bolt pattern is 5 x 115, but will 5 x 114.3 fit on the car or not???
Space Mar 17, 2009 08:10 PM
No ?
:rolleyes:
Hi 05Monte
Below from WebSearch
"No. Even if you did get them to fit, it wouldn't be safe for you to drive the vehicle with them.
The lug nuts must seat in an area on the hole drilled for the studs. If not seated correctly, they could work themselves loose, which means possibly losing a wheel while driving.
(yahoo answer)"
I would check with your local tire store/shop to confirm.
Also Check Out below link, or wait for one of our
Rim/Tire Experts 2 post.
Can we run 5 x 114.3 wheels if our bolt pattern is 5 x 115 .... Can we run 5 x 114.3 wheels if our bolt pattern is 5 x 115? ... does anyone know if 114.3 wheels will fit our pattern? if so that would make my job of finding rims ... I can only see it when I log in, but here's the link ...
www.buickforums.com/forums/showthread.php?t=4632 - 62k - Similar pages
wiz kidd Mar 17, 2009 09:31 PM
they will fit, both of those bolt patterns fit the monte's, as well as the magnum too :)
you will need hub centric rings though, as you would with both of those bolt patterns
just make sure the offset is correct
RickAKATed10 Mar 18, 2009 08:48 AM
They better fit! lol
I researched this as well and you will hear a lot of mixed "opinions" and theories. General consensus is that it will fit, but you need hub centric rings as mentioned above. They're a good idea anyway even if they are a direct fit in my mind.
wheelguy Mar 18, 2009 11:00 PM
The only cars that need rings are BMW'S & benzez. I do this thing every day with no problem but if you get a shake at 40 or less get the hub rings. Any more then it's a balance issue. Doing a 5x4.5 on a Monte does not require a hub ring. Use a skilled shop & you won't have a problem. It is with in dealer specs, & they won't fall off like some say, that's foolish.
wheelguy Mar 18, 2009 11:10 PM
Also, Magnum wheels will not fit the Monte unless the Magnum is an all wheel drive, wrong off set other wise.
steelmalu43 Mar 19, 2009 07:51 AM
I have a set of 18inch SS wheels, These should fit my 06 with no problems, right? Do i need these hub rings?
wiz kidd Mar 19, 2009 08:20 AM
yah i know the magnum is the wrong offset, i was just saying same bolt pattern
RickAKATed10 Mar 19, 2009 08:49 AM
Nope.
nemesis Apr 9, 2009 11:43 PM
what hub rings? my bullitt rims are 5x114.3 and i never use no hub rings
