Originally Posted by ZIPPY02
(Post 735078)
Agree, use the 2002 Camaro dual piston calipers on the front, no spacers required. . I don't have any adversion to the braking performance, seem to be decent to me. I run the EBC "Yellow Stuff" brake pads, perform nicely, litle to no fade when you have them heated up. Used other brands, and after they were hot, you had to get out of it well before the cornering / braking situation developed. Use the ATE Super brake fluids.
Bumpin is right in that tires have a big say in your ability to maintain road contact. I still use my stock GM 5 spoke diamond cut 16" wheels too. |
Originally Posted by gsunderwood
(Post 735081)
Yeah it’s a street car, my brakes are fine but i brake pretty heavily a lot and they get really hot.
I would like having better brakes but if its a pain to do on a street car it’s no problem they’re good enough, but i would like to look into better cooling right now. From what you've mentioned, some quality blank rotors (I use Centric, but there are plenty of options), some performance oriented street pads (I use Carbotech 1520s on my daily GTO), performance tires (like a Michelin PSS, PS4, etc), and fresh performance brake fluid should be plenty for your application. Unless you're doing multiple panic stops from triple digits back to back, this should be more than good enough. That's exactly what I run on my DD 400+ hp GTO with zero brake fade, even on spirited drives well into the triple digits. Would it be worth it to get the crossed and drilled rotors in my case? People used to go crazy about them on w body cars post Fast and the Furious days. "makes it look like a racecar". But once I started getting into F bodies and vettes where people are actually tracking their cars on legit road race circuits, I was very surprised to see how many people ran regular old blank rotors, even on very serious track machines. That really changed my viewpoint on doing them at all on street cars that barely see as much heat in a full trip as these things do in half a lap. As I started to add significant power to my monte, I actually ended up getting cracking around the drilled holes on my 'performance' rotors, so I ended up swapping it back to blanks also. That's all I run on all of my cars including my Vette that I use for half mile racing events up to 160-170 mph. If you're having actual brake cooling issues (i.e. you're dumping more heat into the rotors than they can naturally dissipate / overheating the rotors), then adding a couple % more surface area via holes or grooves is going to be a miniscule drop in the bucket in terms of cooling rate. Do you know any better ways to cool them cause i tend to get them pretty dang hot But- that seems really excessive for a stock v6 street car, thats why I ask how much overheating we're really talking here. The typical case when pushing a stock car is just overheating the pads - creating fade / loss of friction, but that can be easily remedied with a sporty street pad that's matched for the temp they'll actually see. But if you're actually glowing rotors / boiling brake fluid, then perhaps you're using this thing way harder than I'm thinking. |
(Post 735083)
I looked at those on zzp and emailed them, they said i would need to use spacers with my wheels, but if they do fit do you think they would be suitable for street driving?
Read more on the F-body swap here: https://www.w-body.com/topic/55502-f...brake-upgrade/ Review on EBC Yellow Stuff pads: Nothing like what Bumpin rolls with, his are true big $$ pads, but then so is his sick ass Vette, small price to save a Vette. These are very decent though. EBC Yellowstuff R's are the "official" brake pad of the "Subaru Challenge" in the UK. This fact alone has got to say something good about the beating these pads are capable of. So I've decided to give them a go. These pads are true full race spec material and can handle higher temperatures than some of the other options out there. EBC claims they offer good wear life, and that the “bite” from cold is GREAT - - not many true race/track pads can hold that kind of claim. Braking ability/Fade Resistance – I've yet to experience brake fade! Extreme temperatures, constant left foot braking, let's face it, I have been nothing short of brutal on these pads. True that in between stages they do get a chance to cool down a bit, yet on stage, they performed better and better the hotter that I got them. For me, this inspired nothing but confidence in the pad, brakes and car setup. Compared to the EBC Redstuffs - Very similar comparisons. Both are rotor friendly, light dust, no noise, and long lasting. The benefit of the Yellowstuff over the Redstuffs? They can handle higher temperatures. Although I've never had brake fade with either compound, the Yellowstuff seem to hold themselves better the hotter they get! I can feel it in the brake pedal, in the car and the feedback from the car when under heavy/extreme braking. I would have absolute confidence on either compound, but for "faster" more aggressive racing events, you will find me leaning to the Yellowstuff compound from now on. In Conclusion: I would recommend these brakes as a "decent" street pad - but most definitely a full track, rally and race pad. |
| All times are GMT -5. The time now is 02:13 AM. |
