-   Tires/Rims/Suspension (https://montecarloforum.com/forum/tires-rims-suspension-16/)
-   -   5 x 4.5" (114.3mm) --> 5 x 115mm (https://montecarloforum.com/forum/tires-rims-suspension-16/5-x-4-5-114-3mm-5-x-115mm-36423/)
red04montels May 18, 2012 01:02 AM
Originally Posted by jaws2008 (Post 459237)
That's not what I was told. The centric rings center the wheels so its "centered" and wont hop or osolate causing vibration etc. it has no effect on studs. I ran 2 years with out them on my 114.3 wheel till I got new tires and the place I got the tires from required me to get them to install tires. But I never had a problem with out them. My normal shop told me most do not even use them anyway.
Originally Posted by IffyG (Post 459242)
There is no contradiction in my statement. Running hub centric rings ensures your wheel seats properly on the hub. My aftermarket wheels (5x115) were sold with hub centric rings because the center bore is much larger than the wheel hub. Hub rings do not (and will not) ever correct for the wrong bolt pattern, they just minimize the probability you will seat the wheel wrong and stress the studs (the same purpose they serve when using the correct bolt pattern).
Think about it, the hub centric rings center the rim, this would take pressure off of the studs that would be there if the rim wasn't centered. The rim could be pushed off in any which direction which would result in breaking studs.
I never said it corrects the problem, it just helps to take the strain off of the struts because of the rim now being centered better than it would have been.
So like you have said (even tho you said it doesn't affect it) the hub centric rings will help to bring stress off of the studs and help when using 114.3 x 5 bolt pattern, so they do kind of have to do with using the wrong bolt pattern (in this case 114.3 x 5). That's what I was initially trying to get at :thumbsup:
TheMonteMan May 21, 2012 03:08 PM
heres a old sticky from ls1tech on asa wheels.Warning about ASA Wheels. - LS1TECH i have no clue why it was a sticky, and im not sure if the guy with the stud problem is the same guy that posted the pics on the other site, but perhaps the situation with the studs has nothing to do with the bolt pattern and are more to do with that manufacturer. ive never personally run that bolt pattern on my car so i cant speak from experience, but having seen numerous high hp wbodies running mustang wheels, and slicks/drag radials without problems i would say yes its possible to break studs, but not super likely. i mean i can get struck by lightning while typing this cause its storming out, but i think ill be ok. just because something has a small chance of happening doesnt mean it will.
ChibiBlackSheep May 21, 2012 03:49 PM
Originally Posted by IffyG (Post 459026)
Obviously, I'm in the minority on this forum... I'll just shut up now...
You and me both, I just keep my distance from these threads :thumbsup:
monte carlo 3831 May 21, 2012 03:55 PM
Mike, are you saying if we went on a cross country tour you wouldn't drive in my Monte........
ChibiBlackSheep May 21, 2012 03:57 PM
I have AAA, so I would be fine in anyone's car, I just wouldn't do it to my own ;)
monte carlo 3831 May 21, 2012 03:59 PM
I guess it's good that I have triple a also.......:cool:
lougreen03 May 21, 2012 05:14 PM
This is an interesting thread. Here are my thoughts on the subject.
Are the the correct recommended size from the manufacturer? No
Will they fit? yes Run them at your own risk.
PUNK LIFE May 22, 2012 10:05 PM
i thought about saleen rims at one point. called two different tire shops, one said they do 5x114.3 all the time on 5x115 cars, the other act like i was a moron to not match up 'properly'. i didn't trust either and just went with 5x115.
Mr Grizzly Mint May 23, 2012 12:40 AM
I would stick with 5x115.
Here there are over 1000 rims to chose from.
Product List - Vehicle - Chevrolet Monte Carlo 2004
remove the size you chose from the menu. 1600+ rims to pick from. 255 are 18x8 which is what I want to use. All are the correct 5x115 with proper offset. They price match also.
With that many to chose from no reason to run 5x114.3
Monte_Man04 May 29, 2012 11:39 AM
Thanks for the link, I found one or 2 that I liked. Problem is that newer rim designs are so gaudy and ridiculous and that's all that I can find in 5x115. I'm looking for retro, or simple-yet-elegant styling. I'll keep on the look out.
