7th Gen ('06-'07): 255 45 19's
Old Sep 29, 2021 | 10:39 AM
eccles17's Avatar
Default 255 45 19's
Hey guys, newbie here. I found a set of 255 45 19 tires on 19 by 8.5 wide with ET:52 for super cheap and I love the look of them. I have a 2006 Monte Carlo SS with stock suspension. Does anyone know if I can run these without rubbing or anything or is it not possible? Thanks, everyone and I appreciate the help/advice.
Old Sep 29, 2021 | 10:25 PM
Have an 02, run 255 50 16's (Comes with OEM 16's), no rubbing at front, 1/4 spacers at rear to avoid trailing arm rub. You are jumping up one size wheel, bet 19's would clear. And they are only 255 45's, a bit narrower than 50's. If they do rub just add spacers. There are always the Pro's and Con's crowd regarding use of spacers. I had all new ARP wheel studs installed, so not worried about snapping lugs off when cornering etc. Plus the shop that built my car said they are nothing to worry about, he actually put them on to stop the slight rub at the rear.
dbaldwin
Mar 29, 2014 09:12 AM
S.O.G.
Jan 10, 2013 11:17 PM
Crunk Emperor
Jan 9, 2012 02:44 PM
03pacecar
Nov 28, 2006 10:58 PM
soca ss
May 21, 2006 03:35 PM
