Torque Specs Please
Torque Specs Please
Can someone with a 2000-2004 Monte shop manual supply the following torque specs?
Front and rear sway bar cushion clamp torque.
Front sway bar link torques.
Front and rear strut mounting bolt torques, both top and bottom fasteners.
Rear lower control arm mounting bolt torques.
Rear sway bar connecting link nut torques.
I am installing the GMPP suspension upgrade kit.
TIA
TIA
RE: Torque Specs Please
[align=center]Hi Joe,[/align][align=center]If no member has the spec`s, you might want to [/align][align=center]call the below number for the torque specs.[/align][align=center]1-800-545-0048[/align][align=center]or[/align][align=center]Contact your source where you purchased.[/align][align=center]Good Luck, & let us know how the install goes.[/align][align=center]`Space[/align][align=center]GMPP suspension parts from the GM Performance Parts (GMPP) [/align][align=center][/align][align=center][/align][align=center]This page shows the GMPP suspension parts from the GM Performance Parts (GMPP) catalog.[/align][align=center]http://www.gilbertautoparts.com/Susp...arts/index.cfm[/align]
lui carlton
04-23-2011 08:03 PM
