20's or 22's
RE: 20's or 22's
20'S ARE THE WAY TO GO, 22'S WILL ALSO STRESS YOUR BRAKES OUT TOO, I HAVE 20X7.5 I KEPT EVERYTHING THE SAME AS A STOCK WHEEL EXCEPT I WENT TALLER BY 3. MyTIRE PROFILE IS 35 BECAUSE THEY ARE A Z RATED TIRETHE WIDTH IN MY TIRE AND WHEEL ARE THE SAME AS THE STOCK 17'S. IF YOU WANT A NICE DISH GO 20X8.5 AND JUST MAKE SURE YOUR WHEEL OFFSET IS CORRECT TO YOUR VEHICLE. 20'S ARE GREAT FOR PERFORMANCE AND THEY LOOK GREAT. DISCOUNTWHEELWAREHOUSE.COM IS WHERE I GOT MY WHEELS, CALL BEFORE YOU ORDER THEIR STAFF OVER THE PHONE MAKES SURE YOUR OFFSET WILL BE CORRECT AND THEY CAN TELL YOU WHAT WILL FIT PERFECTLY AND THEY CAME MOUNTED ALL I HAD TO DO WAS HAVE DISCOUNT TIRE PUT THE WHEELS ON THE CAR BECAUSE I DIDN'T HAVE A GOOD JACK FOR THE JOB.
http://www.cardomain.com/ride/2724733
RE: 20's or 22's
ORIGINAL: wheelguy
Nope, it's either an offset or tire size issue, nothing to do with the dish I guarantee.
ORIGINAL: tlip06
even if u go 20's depending on how deep your lip is on the rim it could even hurt your tire.
my brother has 20's on his 02 trans am and in the back his tires rub everytime he hits a bump. his tires are literally ripping up on the sides. he a very deep lip. it would not do this if the lip wasn't so deep
RE: 20's or 22's
ORIGINAL: mavrickf1613
But they do look great!!!
RE: 20's or 22's
ORIGINAL: blackice
if i add an K&n intake and a magnaflow exhaust system would i get all of the power back or at least some of it??
yes... you'll gain a lot back. im not sure how much the 22's are robbing you of, but, you should be back to at least around stock performance.
