20" rims rubbing in rear....HELP
Old Jun 12, 2006 | 12:59 AM
BigPunSS's Avatar
Default 20" rims rubbing in rear....HELP
Ok I have some Nitto Extreme tires size 255/35/20 and the front is fine but every time I hit even the smallest bump the back tires scrape horribly. I already have to buy two new tires but has anyone had this problem or does anyone know what may be the problem or why only the rear tires rub? Any suggestions would be helpful. Thanks
Old Jun 12, 2006 | 01:02 AM
The Black Machine 29's Avatar
Default RE: 20" rims rubbing in rear....HELP
i have the same size tire on my 20's and no problem
i have no clue but good luck
Old Jun 12, 2006 | 01:17 AM
DESS03's Avatar
maybe your struts are worn out do you have a heavy audio system in the back and whats the backspacing on your wheels it might not be correct
Old Jun 19, 2006 | 11:22 AM
warrantykiller04's Avatar
go to universalcarlifts.com they have an easy to install 5 in. lift to "fit 22-26 in rims." i saw one on ebay for 140 bucks.
Old Jul 23, 2006 | 07:51 PM
Double Deuces's Avatar
mine rub real bad *22 inch 265/40.22*when i make a turn with out stopping the rear driverside cuts the tire and if i tur more than a corner turn of the wheel the front always rub but the front dont really slice as much as feels like e brake engages and makes car almost come to a stop.huge pain when i have reverse and cut the wheel i have to over half throttle it to make it go. lol!!! i also hvae very big wheel spacers on all 4 and spring blocks just in front because there is brand new shocks in rear for a huge lift floorboard comes up about to my kneecap when standing out side the door oh and i kave no heavy stereo system in the trunk its empty (no weight)
[IMG][/IMG][IMG][/IMG]
Old Jul 26, 2006 | 06:07 PM
DESS03's Avatar
yours are just plain to big for the car
Old Jul 27, 2006 | 04:59 AM
Bigg J's Avatar
yup [sm=exactly.gif]
Old Sep 9, 2006 | 06:02 PM
MonteOnDubs's Avatar
just lift it.
btw, the rims are not too big for the car.
Old Sep 10, 2006 | 03:18 PM
DESS03's Avatar
imo if u have to lift a car the wheels are TO BIG it destroys the ride braking suspension and overall performance of the car
Old Sep 10, 2006 | 03:27 PM
montejass's Avatar
This is just my opinion, but I think that Monte is already too high in the air with 20's..
I am not sure I am a big fan of huge rims on anything for that matter.
