real 'nas car
1 Attachment(s)
This is my 2001 Monte Carlo SS. It has a NA 3800, which I am intending on doing a top swap onto.
This car was given to me by a friend who just didn't want it anymore. Attachment 36489 |
3 Attachment(s)
Driving it home, it had a bit of a drive shaft chatter, so I got underneath and had a look.
Attachment 36486 Attachment 36487 Attachment 36488 Tires are in great condition, right? |
1 Attachment(s)
Popped the trunk and apparently the weather stripping is leaking. The spare tire well was filled with water. Drained it and pulled all the carpet out.
Attachment 36485 |
5 Attachment(s)
Replaced the left half shaft, and outer tie rod
Attachment 36480 Also replaced both front wheel hub assembly Attachment 36481 Front rotors Attachment 36482 Replaced rotors, calipers, pads, hoses Attachment 36483 Attachment 36484 |
it's a shame how some people neglect their cars
Yep. There are other problems too.
The dash is intermittent. It has an aftermarket remote start that seems to be the only way to start the car, if it feels like it. I need to replace the accessory belt, but will do that with the swap. Possible head gasket leak. Again, will deal with this during the top swap. The speakers aren't working. |
I'm envious! I got an '01 same color as well with even more problems, and I bought it. It test drove great, but like after a week of driving it, it started showing all it's problems left and right... Good luck with all your repairs! It has a lot of potential, and frankly it's straight and good paint, so frankly the other stuff is just nuts and bolts.
what size were the 3 wheel hub bolts and the half shaft nut?
Unfortunately I can't recall. I could check for you, if you just mean wrench/socket size...
yeah, I've been told the axle nut is either a 33, 35 or 36mm, I haven't found any info on the 3 wheel hub bolt sizes yet...
