Help Needed!! Thanks in advance...
Im building a 383 using AFR 195 cylinder heads, is it possible for me to build a combo that would allow me to running the mid to high 6's on motor? 350 trans, 4.10 gears, 4000 stall, lunati 30120533 cam if yall need more info let me know...
Welcome to the MCF.. Anything is possible if you have the knowledge, ability, parts, tools & $'s to get a vehicle into the 6's...would need as much information as you can post for our expert motor head member's to reply...
Check the below links & hopefully they will help or give your some idea's. Good Luck.. 383 Stroker Upgrades - Project Homewrecker - Super Chevy www.superchevy.com › Super Chevy › How To › Engines & Drivetrain Air Flow Research was tasked with supplying our cylinder heads and they had ... and it sent us a set of 195cc SBC Eliminator Street cylinder heads (P/N 1040; ... 383 Small-block - Lethal Weapon Project - Top Gun - GM ... www.superchevy.com › ... › How To › Engines & Drivetrain See how to install the AFR 195cc SBC Eliminator Street cylinder head to a 383 ... on Lethal Weapons' 383 engine build with a set of AFR cylinder heads and an ... of Air Flow Research 195cc Eliminator cylinder heads for our 383, which flow ... AFR 383 dyno numbers? [Archive] - NastyZ28.com www.nastyz28.com › ... › High Performance Modifications Jul 20, 2011 - 16 posts - 8 authors 383 10:1 compression 1 3/4" headers. AFR 195 heads .510/.520 lift roller cam. RPM Air-Gap ... AFR SBC 195 aluminum cylinder heads, 74cc, straight plug ... With those big 74cc heads what is your compression ratio? I would ...Head Selection Help for 383 16 posts Nov 24, 2012 195cc vs 210cc 64 posts Nov 27, 2011 AFR 195 Eliminators 45 posts Dec 17, 2010 Joe Sherman tests the new AFR 195 heads: 615HP 383ci ... 84 posts Dec 23, 2006 More results from www.nastyz28.com Dyno Tests - Air Flow Research https://www.airflowresearch.com/dyno.php Use keywords to find the product you are looking for. Advanced ... Dyno Tested Packages with Proven Power and Performance. Featuring AFR Cylinder Heads ... Small-Block Chevy Engine Upgrades - Hot Rod Magazine www.hotrod.com › Hot Rod › Engine › News Jun 1, 2007 - For the test, the 383ci short-block, less cam, remained in its original, .... New AFR Eliminator 195cc intake port street heads equipped with ... https://www.youtube.com/watch?v=F0wiZZdFVbY Feb 24, 2012 - Uploaded by Fred White 562 HP 383 Engine w/ AFR Heads Dyno Testing ... sweet I dynode my 383 today it did 567 hp and 540 ... Engine combo try #2 AFR 195-383 sbc. - Chevy Nova Forum - Steve's ... www.stevesnovasite.com › ... › Drivetrain & Performance Jun 10, 2008 - 16 posts - 10 authors -383 sbc using 14010207 block and Scat 40760BI rotating assembly put me ... -AFR 195 heads (75cc combustion chamber) 280 CFM @ .550 .... I know with the right cam etc to bleed off cylinder pressure it can be done, but I'm ... AFR 195 Eliminator Build Recommendations - The BangShift.com Forums www.bangshift.com/.../390-afr-195-eliminator-build-recommendations Dec 3, 2007 - 10 posts - 5 authors 383 with the new AFR eliminator 195 heads (they flowed 265/217at ... How do you think this cam will perform with the AFR's in a 355 or 383? AFR Heads Dyno Tests Chevy - Strokerengine.com www.strokerengine.com/AFRchevyDyno.html Featuring AFR Street Heads, AFR Hydraulic Cams, and AFR Manifolds. Efficient ... Fuel: 460 HP 383cid. AFR Street 190 Aluminum Cyl. Heads 9.5. Holley 0-80779 750 cfm ... BG Silver Claw 750 Carb. with 75/83 Jets MSD 85551 ... Manifold: 574 HP 413cid. AFR 195cc Cyl. Heads 10.5 to 1 750 carburator 36° Timing Custom ... Afr SBC 195cc Aluminum Cylinder Heads 383 350 CNC ... www.ebay.com › ... › Cylinder Heads & Parts eBay $1,597.59 - In stock This auction is for a BRAND NEW PAIR of AFR Eliminator Chevy 195cc Fully CNC-ported cylinder heads with 65cc combustion chambers, IN STOCK, on OUR ... |
I'm a nu-be and wondering how your combo preformed. You shouldn't have had any trouble getting into the 6's, I'm running a nothing 350 (L-82) w/ iron 2.02 heads and a cam close to yours and clocking 7.14
