Anyone know what kind of power the 87SS is making?
Hi Guys! My Dad and I just put a 350 in his Monte Carlo SS. I was wondering if someone had a similar combo to his, or would know approx. what kind of HP/TQ he should be making? Thanks alot.
Combo is: -350 cubic inches -All cast bottom end -9.5 CR -Alum heads with 2.02/1.60 valves -Comp Cam 224/230 .477/.480 lift with 1.5's -1.5 Roller Rockers -Holley Street Avenger Carb ( I believe it's the 570cfm). -Edelbrock Performer intake -Stock 200R4 tranny with a hard hitting shift kit The car was setup and it shifts at 5200 RPM's right now, but I know is needs to be brought up to around 5800 RPM's, as that is where the cam is supposed to peak out at. The car also has the factory 3.73's, and we put in a GN stall converter(2200) to replace the factory 1600 rpm stall. Also if you have any idea what it should run in the 1/4 mile? I am mainly into C4's, and fuel injection, but I am learning. The car will spin the tires without a problem from a dig, and it you stall it up, it will roast the tires all the way threw 1st gear. |
RE: Anyone know what kind of power the 87SS is making?
Hi `H & Welcome 2 the MCF Sounds like you & your dad have a Super MonteCarlo Explore the Forum & check out the Drag section to check on 1/4 mile times etc. Look forward to your future post & you becoming an active MCF member. EnJoy your Monte Also Check the below site for reviews on the Monte Carlo [:-]Click below link [:-] `Space |
