Fuel lines
Drove over a tree stump in the 2003 Monte SS, my fuel lines are dented right behind the transmission. Brake lines are fine. Looking for all three fuel pipes.
Just repair the dented section with new line instead of replacing the whole thing
(Post 613985)
Do not use rubber hose and clamps. If the rubber line leaks you'll be spraying fuel all over a hot exhaust system. I think you can figure out what would happen next. :eek: |
Originally Posted by 03SSLE
(Post 614075)
If you do this cut a section of line out and replace it with a metal section. Double flare the pipe and use compression fittings.
Originally Posted by dc1
(Post 614086)
Is there a recommended kit and guide out there for this?
Originally Posted by Habbibie
(Post 614095)
I don't think u have any knowlage about what they're talking about. Take it to a mechanic and be done with it
(Post 614086)
(Post 614095)
Originally Posted by ZIPPY02
(Post 614127)
Agree if it's out of your league don't try and save a buck when it comes around to messing with fuel under pressure next to a hot exhaust. Get it wrong and it's Game Over...
X3 This is not a job you'd do step by step from a manual. That is the impression I get by your question. Have it repaired by a professional. |
