7th Gen ('06-'07): tail light bolt broke
Old Apr 19, 2012 | 02:17 PM
monte07's Avatar
Angry tail light bolt broke
ok i dont know how it happened it ended up breaking when i was taking it off it is the top stud that broke. i dont get it i was changing two of the bulbs that burned out. i noticed the top of the other one doing a wiggle like it is lose and i am afraid to look i am going to just up grade to anouther set. is there anouther type than stock wich are expencive
Old Apr 19, 2012 | 02:25 PM
monte07's Avatar
sad news is i didnt want to upgrade my tail lights yet but the ones i found the led type is cheaper than stock. the stock ones 285.65 a peace the led type 318.75 for a pair i just hope that the originals will last till the end of next month
Old Apr 19, 2012 | 02:32 PM
Enzo354's Avatar
STILL SLOW
Get some stock used ones off of ebay.
Old Apr 19, 2012 | 05:51 PM
Barovelli's Avatar
I'd try some JB Weld to patch it together until you are ready to replace them.
It did me good on a door panel.
Old Apr 19, 2012 | 06:07 PM
DuSSt's Avatar
I would try JB Weld or silicone or some adhesive if you want to fix what you have now, could get you by anyways.
I had a cracked lens, and looked into just replacing one, of course from chevy it was absolutely ridiculous. I personally found it had more value to me personally to just upgrade them to led which look better anyways in my opinion, for a cheaper price, unless you can find a set of stock ones really cheap.
Old Apr 19, 2012 | 06:38 PM
BlackRainSS's Avatar
Ouch thats a bummer man.
Old Apr 19, 2012 | 06:46 PM
since it's plastic i'd use some epoxy to bond it back together.
had to do that on the side mirror for the Alero.
Old Apr 19, 2012 | 09:47 PM
Before dropping big money on this, I'd do as suggested earlier, JB Weld or a GOOD 2-part plastic epoxy! I've had great luck with both products in situations I thought they would fail.
Old Apr 20, 2012 | 06:51 AM
monte07's Avatar
i had it in the body shop last year i didnt notice that they used already apoxy to cover there fuge up. i should have looked at them when i got it back from the body shop. i have to get in contact with my insurance about it that they broke them and tryed to cover them up
Old Apr 20, 2012 | 09:44 PM
One Dark SS's Avatar
why not just tap the plastic and use a proper sized bolt? or just a right diameter screw with some washers on in the inside of the trunk?
izmouse
Mar 20, 2012 03:29 PM
shock081
Jul 14, 2010 09:00 PM
Mex24x
29
Feb 17, 2010 12:35 PM
gohawk72
Oct 2, 2009 02:14 PM
mikeymontecarlo
May 1, 2008 02:41 PM
