painting my engine cover?
My monte is white with red checker design - i saw someone who did a white,red and black cover. Does it hold up any suggestions?
Check out hydrographics. All you need is a vat of water, the vinyl design of your choice, aerosol activator, and the part you want the design on. The vinyl design is cut to the correct size and floats on the water. After the aerosol activator is applied to the vinyl it gels and when the part is dipped in the pattern is perfectly transferred to it. You can do any design they have a pattern for. I think red carbon fiber would look good for your project because carbon fiber has a checkered look to it anyways.
1 Attachment(s)
Or you could paint it... They hold up... Here's mine... Good luck... Let us know what you go with...
Originally Posted by Crusader SS
(Post 589713)
Originally Posted by matthewboyleZ34
(Post 589782)
Wow you did a great job on that!
(Post 589801)
Thanks. By the way, sweet looking Monte... :thumbsup:
(Post 589811)
As is yours... Mine is still a WIP and the pic is the final look I'm going for. It's kinda like how Chip Foose does a rendering and builds to it. If you don't know where you want to end up, it's hard to get there...
thanks
thanks for the replies - i loved the way yours came out crusader ss .... did you use high heat paint gloss white and then clear coat it? what did you use for the red- touch up pen?
Originally Posted by dgm
(Post 589825)
(Post 589713)
