paint sealant?
https://montecarloforum.com/forum/me...lola-12628.jpghttps://montecarloforum.com/forum/me...mart-12627.jpg
this is annoying :mad: the paint on the bumpers looks good when its wet think paint selant would work and where could i buy it |
Wow looks like you are dealing with a clear coat issue. Another application of clear coat won't look good for too long if placed over that problematic clear coat you already have.
I would suggest a fine water sand before re-applying more clear coat. Check out a body shop before doing anything. They may offer suggestions. |
well i waxed it this summer it hellpedhttps://montecarloforum.com/forum/me...anup-12440.jpg
Paint sealant isnt going to solve your problem. It looks to me like your clear coat is peeling/worn through. The only thing thats going to fix that is a repaint. Just re-clearing a peeling panel isnt an option. You will see the edge of the old peeling clear if you sand and clear over it. You would need to sand it down and at least re-base it to cover it up before re-clearing.
i just wanna make it look ok for cheap like 40 dollars or less
Yeah theres no real cheap fix cuz the base will be a diff color aswell if u just reclear
paint work is the only thing that is going to fix that
