Nasty Ass Headlight Question
Is there an aftermarket product that actually works to refinish these headlight capsules, or do I just need to suck it up and pay Sam's the $30?
(This is one of those times I really miss the Aurora. Olds used the higher-quality plastic that Cadillac still uses. Two applications of Meguiar Plast-X every six months and I was good.) |
What are you doing, getting the yellow off? They have kits but I never used them to much success since my headlights were too bad by the time I got around to them - but that's my fault.
I've wet sanded my 04 GP with great results. |
You can clean them, but unfortunately when they start to haze, it's because all of the protectants in the plastic are gone.
I've successfully wet-sanded and cleaned before, but within a year they were hazy again. Full replacements are the best bet IMO (if you are keeping the car longer than a couple of years) |
I painted mine and wax them. about 1 year so far no problems. I'll try to keep posted; maybe I'll start taking a pic at the 1st of the month to see if there is any changes.
Latest thing I tried is the Turtle Wax $9 kit. The passenger side is passable. No response on the driver's side. Then I tried wet sanding. It looked great after the last time I rinsed it off, then within an hour, all hazed over again....
(Post 698057)
When you wet sand them, you'll need to put something on them. Again I painted mine and wax over the paint. I don't think I took a before pic but I'll see about getting a pic soon.
Most body shops spray a layer of clear coat after wet sanding.
I couldn't possibly have gotten a coat of clear coat on and had it dry before the haze returned to mine.
I'm sucking it up and having Sam's work on them tomorrow. I just can't stand to look at it another day. |
For what it's worth a friend of mine Wet sanded his. Began with 400 and ended with 2000. Then he used a floor wax on the plastic, It used to be called Future floor wax, some one bought them out and it is still available under a different brand. (pledge floor care) he said it is holding up so far. :confused:
Been 6 months and on occasion he will recoat with the wax. |
