Nascar Type tires
Old Jan 3, 2014 | 08:07 PM
Here in Canada you pretty much have to special order tires with raised white lettering. So few people want them anymore, most tire shops don't stock them.
Old Jan 4, 2014 | 01:10 PM
soleinova's Avatar
Originally Posted by zjerry
They last about 3 to 4 Months before I have to redo..
I was thinking of buying a marker and do the same as you. They look good, so I'll give'em a try. Thanks.
Old Jan 4, 2014 | 01:15 PM
soleinova's Avatar
I have another question, is regarding the headlights. I need to replace the old headlights, and I'm thinking of buying the DEPO Euro Style headlights, are they a good buy or I should stay with the OEM?
Depo 00 05 Chevy Monte Carlo Euro Style Black Housing Headlights Dot SAE Pair | eBay
Old Jan 4, 2014 | 01:33 PM
dbaldwin's Avatar
Mike (Chibi) says they hurt light ouput a lot. Stick with OEM.
Old Jan 4, 2014 | 01:46 PM
Mike 00LS's Avatar
X2
Unless you're planning to add HIDs. Also, with aftermarket headlines you often have to seal them up good when you first get them or they'll probably start to take in moisture and fog up.
Old Jan 4, 2014 | 01:49 PM
soleinova's Avatar
Originally Posted by Mike 00LS
X2
As a matter of fact I got HIDs installed. Still, should I stick to OEM then?
Old Jan 4, 2014 | 01:51 PM
dbaldwin's Avatar
If you have a 5000k or 6000k kit it might be be a courtesy to other drivers to reduce the light output. If they are 10000k + stick with OEM.
Old Jan 6, 2014 | 11:10 AM
soleinova's Avatar
I'am buying the duplicolor HT300 marker but I want to know if one is enough to paint the four tires?
Old Jan 6, 2014 | 01:06 PM
Here's a LINK:http://www.durablesupply.com/exbroadpoinp.html
I bought only one and have used it alot.., I may have to buy a new one in the spring after afew cars shows..
You have to paint them like 2 to 3 coats .. Lasts a long time.
Old Jan 6, 2014 | 03:14 PM
soleinova's Avatar
Thanks for the info! What's the difference between this marker and the duplicolor? Posca is half the price than dupli...
