mystery clip need help
few days ago i was taking apart my rocker panels,had no problems other then this clip that attaches to each end of the rocker panel next to the screw i been to two dealerships where they dont have it and was hopeing someone could identify this part.like i said it is the plastic clip right next to the screw on the end of the side rocker panels facing the wheel wells.thanks its a 01 monte ss
this pic is one thats broken cause it was impossibe to get out cause when installed the stem expandes out http://i250.photobucket.com/albums/g...4/IMG_1598.jpg |
The Parts department at the dealership shoiuld have no problem ordering this clip for you.
You can also try gmpartsdirect.com. But I do not know the exact name of the clip? Other then a push clip cause the center is pushed in to secure it. |
The official name of this part is "retainer" I have these things in various locations on my car. I think they're all the same size. The list price is $0.81, but if you're lucky, they are discounted to as little as $0.48. See part #4
http://www.trademotion.com/schematics/C/CR95010.gif |
if you go to a local store like oreillys or something they should have a display of a whole bunch, its like 3 bucks for a little pack of 5 or something.
I don't think that it's a push style clip. I am pretty sure that they are called "plastic rivets".
http://i748.photobucket.com/albums/x...stic-rivet.gif They are fairly cheap. To set them in place, you pull the center pole out (right side) and it breaks off. Locking the rest in place. |
