LH quarter window leaking water at the top
I've tried using rtv across the top on the outside where the water appears to be coming in at, but it's still leaking. I've called some of the glass companies and they act like it has to be sealed from the inside and that cost $50-$75....or $100-$150 if they have to R&R the glass. Anyone else have this problem yet?
I tried twice to seal it using rtv and no luck....I called 3 glass places and got about the same price just to try and seal it from the inside...$50-$75.......and $100-$150 to R&R the glass. Then I called Safelite and the gal asked if I had insurance?....yes...I do....comp..$100 deduct....she said that they would just replace the window with a new one and all it'll cost me was $100. That was last Friday and Safelite showed up at work on Monday at 9:00am and had the new glass in within an hour....the only differences I saw between the glass was the PPG stamp is now PGW and the seal next to the door is all rubber with no felt like the original....haven't washed the car to see if it leaks yet...hope it doesn't.
