Installing Foglights/Driving Lights
Old Jun 1, 2011 | 06:04 PM
Boomer's Avatar
Default Installing Foglights/Driving Lights
I was wondering if anyone has installed a set of foglights/driving lights in their 2006/2007 Monte Carlo that did not have them installed from the factory.
I would like to install a set of OEM or OEM like foglights and would like recommendations on what product would fit my car with little or no effort to install them.
I am looking for a total turnkey solution lights, wiring, switch, etc.
Thanks
Old Dec 8, 2014 | 06:18 PM
DA_MAN_WIT_A_PLAN's Avatar
I wish someone had some insight. Looking for the same thing! I've heard its not easy
Old Dec 9, 2014 | 08:05 AM
I have a 5th Gen...
However...
I had mine installed via an auto accessory shop. They are turn key operable... Via an illuminated switch...
I believe ..even though there aftermarket... They look like a factory option/install .
I have changed the look on mine somewhat... But I'm still using the Fog Lights! (Had to replace them as I had one lens that was cracked)
Attached Thumbnails Installing Foglights/Driving Lights-wp_000293.jpg
Old Dec 9, 2014 | 09:29 AM
You could probably find oem or at least look a like oems on ebay. At least for the 6th gen to me they are just for looks since they don't really shine like my low beam headlights. To get them so they are on only when the car was on is just wire them into a fuse that is only on when the car is on. You could wire a switch in the car so they are not always on and turn them on whenever you want. I would run a wire into the engine bay and run a relay so the lights would run off the battery.
jschmidt
Jun 24, 2008 09:12 PM
jeffsmonte
Oct 4, 2007 10:11 PM
fastback4
Feb 6, 2007 02:34 AM
dark006
Jan 8, 2007 10:14 AM
06BlackSS
Oct 23, 2006 10:09 AM
