Ground effects question
So on the 06' Monte Carlo SS on the ground effects in the front it has the plastic part. Does anyone know if you can replace just that piece or do you have to go out and buy a whole new front ground effect. Before I had got the car someone must have driven over something because the plastic is scratched up and broken a little in one spot. You can't tell unless you are washing and detaling and getting up underneath it. But I know it is there and it bugs the hell out of me lol. Thanks in advance
Could you post some pic's ?
I will post some up tomorrow if I have some time
If it's not cracked you can probably sand it down and paint it :)
(Post 532230)
I've seen some ground effects with it removed and it is indented in that spot, but I'm not sure if it's clipped there.
Hopefully someone has the answer for ya! |
Yea it's meant to take hites or whatever you want to call them, rather then having painted ground effects and hitting something and ruining your paint in that spot. But I'm trying to get my car as perfect as I can so I can start going to car shows and everything
Yes that insert piece (#24) can be replaced on its own. I had the dealership replace that piece on mine when they repainted the front end. It's held underneath the front bumper with four plastic clips and it has tabs on the upper part that slide into the ground effect. Part is $115 at the dealer. The retaining clips should be the reusable pin ones and I'm pretty sure you could easily replace it at home in 5 minutes.
http://www.shop.gmpartscheap.com/sto...sC/CG06010.gif |
(Post 532345)
