fog lights
How do you get to them? And can you seperate the housing?
Factory housing? I'm sure you could if you look at it. As for getting at them, I went under the car and removed the plastic shroud thing under the front bumper allowing me to easily access the aftermarket fogs I put in since mine didn't come with any. It also really helps to remove your headlights on whatever side your getting at.
i ended up getting the harness headlight switch with the fog light switch built in and the fog light assembely. you can take the head light housing off to get to the spots for the fog light assembely. but i had to take my bumper off to put on the wire harness to get the fogs to work it is a new harness that replasses the one that just has the head light wire harness and relay in the relay box. i kept the rest. it was a two part type of harness ironically for my generation. wich is the 7th. when i got closer to the wires that controlled the head lights i mean close to the fire wall that part of the harness is a two peace set up. if you have the 6th i think it has a different set up.
