03SSLE |
03-19-2012 09:12 PM |
Although I've never done a fender R&R on my Monte, the first thing they say to do in my manual is remove the hood. However, if you can support the hood I'd think that you could just remove the spring clip on the end of the hydralic support then pop it off the ball stud. On each end of the support there are slots that the fingers of the clip go into. Using a small flat tip screwdriver (or similar device) you can carefully pry the fingers out of the slots, then pull the support off the ball stud. Keep one hand over the clip so it doesn't go flying and wear safety goggles. ;) They also mention removal of the inner fenderwell splash shield and the front bumper cover, so (if they aren't already) they may need to be removed also.
