Adding fog lights
Adding fog lights
Alright, so those little cheap things they put in the ls bumpers instead of actual fog lights? Yah, well, one fell out on me (hit a bird) and the other is pretty close.. Just wondering what were some suggestions on fog lights I should put in there and where I would get them. Also, if anyone knows exactly how and where I can wire them up, that would be appreciated as well.
i got the original fog lights and brackets from an ss monte, they didn't program the original switch to work with the ecu tho so i wired mine to a rocker switch, you may want to do the same, the fog lights will be hard to find so you may be better off with just putting a normal fog light kit from any store, just measure to make sure they'll fit, and theres a bumper support behind the cover that you can mount the aftermarket to pretty easily
Thanks to Tremayne for the find. lol J/K
but yea with my 2002 LS it didnt come with foglights just the vents so i cut the vents off and i had to steal foglights with the brackets from a junk yard i didnt have the switch so i just wired them to my lowbeams and upped the fuse :-)
Originally Posted by tremayne0126
Originally Posted by Enzo354
Buy those ones.^^
Mogwog, your lucky to have those now haha. I just looked at them and now ill have to pay double for them! But I guess it will do. So how does the bracket mount on my bumper? There is quite a lot more there than I imagined. And I will most likely wire them into an aux fuse and have a rocker switch for them.
