-   Paint/Body Work/Exterior (https://montecarloforum.com/forum/paint-body-work-exterior-32/)
-   -   7th Gen. tail lights on 6th Gen. Monte (https://montecarloforum.com/forum/paint-body-work-exterior-32/7th-gen-tail-lights-6th-gen-monte-16576/)
Frosty LS1 Oct 15, 2009 02:55 AM
Someone, (chibiblacksheep) told me it was possible to swap the 7th generation tail lights onto a 6th generation Monte Carlo. Personally I think the 7th generation's tail lights are its best feature, better than what the 6th generation carries. I'd like to swap them out if I can. Is this possible? How difficult is it to swap them out? And any ideas on where I can pick up 7th Generation tail lights?
Enzo354 Oct 15, 2009 07:30 AM
Members have done it before. You can pick them up on ebay or at a local junkyard. And for the easy of install, if you cant take out a tail light, you cant replace them.
JAFO Oct 15, 2009 08:02 AM
I have to believe that if Mike told you it was possible you can take it to the bank. Doubt if he would say anything unless he was sure of it.
I seem to recall this issue before, someone had swapped them out. The lower inside (at the trunk) corner and the very bottom are shaped a little different but from the pictures I recall you had to look REALLY close to see it. Or at least thats my recallection. Might try a search for taillights and see what comes up.
ChibiBlackSheep Oct 15, 2009 08:21 AM
That is correct, there is the TINIEST bit of spacing that wasn't there for your stock lights, but it does not look bad at all / is that noticeable.
As for where to purchase, I would second ebay. Saw them there a bunch of times. Or maybe you can find someone with a 6.5 who bought the LED tails and is parting their stockers.
Dale3goodwrench Oct 15, 2009 08:45 AM
2 Attachment(s)
here is a pic of what thy would look like on your car. Where are you located at in Indiana?
JAFO Oct 15, 2009 09:32 AM
^^^ Yeah, those were the pictures I was thinking about
RickAKATed10 Oct 15, 2009 10:37 AM
I personally wouldn't want the 6th gen tail lights either. You also have the LED option.
Good question above, where are you located in IN?
TheMonteMan Oct 15, 2009 01:09 PM
i like the 6th gen lights better.
RickAKATed10 Oct 15, 2009 01:22 PM
Trade some one, make a member happy!
TheMonteMan Oct 15, 2009 01:46 PM
neg. i like to keep all the stock stuff too. just in case i go to get rid of it and someone wants it back to stock.
