7th Gen. tail lights on 6th Gen. Monte
Old Oct 15, 2009 | 02:55 AM
Frosty LS1's Avatar
Default 7th Gen. tail lights on 6th Gen. Monte
Someone, (chibiblacksheep) told me it was possible to swap the 7th generation tail lights onto a 6th generation Monte Carlo. Personally I think the 7th generation's tail lights are its best feature, better than what the 6th generation carries. I'd like to swap them out if I can. Is this possible? How difficult is it to swap them out? And any ideas on where I can pick up 7th Generation tail lights?
Old Oct 15, 2009 | 07:30 AM
Enzo354's Avatar
STILL SLOW
Members have done it before. You can pick them up on ebay or at a local junkyard. And for the easy of install, if you cant take out a tail light, you cant replace them.
Old Oct 15, 2009 | 08:02 AM
JAFO's Avatar
I have to believe that if Mike told you it was possible you can take it to the bank. Doubt if he would say anything unless he was sure of it.
I seem to recall this issue before, someone had swapped them out. The lower inside (at the trunk) corner and the very bottom are shaped a little different but from the pictures I recall you had to look REALLY close to see it. Or at least thats my recallection. Might try a search for taillights and see what comes up.
Old Oct 15, 2009 | 08:21 AM
Thanks
That is correct, there is the TINIEST bit of spacing that wasn't there for your stock lights, but it does not look bad at all / is that noticeable.
As for where to purchase, I would second ebay. Saw them there a bunch of times. Or maybe you can find someone with a 6.5 who bought the LED tails and is parting their stockers.
Old Oct 15, 2009 | 08:45 AM
Dale3goodwrench's Avatar
Monte Of The Month -- March 2009
here is a pic of what thy would look like on your car. Where are you located at in Indiana?
Attached Thumbnails 7th Gen. tail lights on 6th Gen. Monte-tail-lights-005.jpg   7th Gen. tail lights on 6th Gen. Monte-tail-lights-008.jpg
Old Oct 15, 2009 | 09:32 AM
JAFO's Avatar
^^^ Yeah, those were the pictures I was thinking about
Old Oct 15, 2009 | 10:37 AM
RickAKATed10's Avatar
Photobucket
I personally wouldn't want the 6th gen tail lights either. You also have the LED option.
Good question above, where are you located in IN?
Old Oct 15, 2009 | 01:09 PM
TheMonteMan's Avatar
i like the 6th gen lights better.
Old Oct 15, 2009 | 01:22 PM
Photobucket
Trade some one, make a member happy!
Old Oct 15, 2009 | 01:46 PM
neg. i like to keep all the stock stuff too. just in case i go to get rid of it and someone wants it back to stock.
