5th gen fog lights
Has anyone installed forgs on their 5th gen? If so, then where... im talking to mainly those with the ls or z34 without the body kits. (Im not a big fan of the razzi)
Please include the type of lights you used and the where/ how you mounted them... also, pics are always useful |
Check out mod Matt (mrl390) Monte, he put fogs on his....
https://montecarloforum.com/forum/me...5B1%5D-504.jpg |
I used Hella Optilux 1500 fogs. I mounted the brackets to the bottom of the bumper beam. I held the lights and brackets up in the opening in the bumper cover and marked a general location with a magic marker. The I removed the bumper cover. I found the center of the bumper beam and measured equal distance on each side from the center line to where I wanted the fogs mounted. Then I marked where the holes needed to be and drilled the holes in the beam. Once I drilled them I mounted the brackets and ran all the wiring. After the wiring was run I replaced the bumper cover and mounted the fogs to the brackets. You should be able to do the whole install in an afternoon.
