View Poll Results: stay hubcap-less
YES
15.79%
NO
16
84.21%
Voters: 19. You may not vote on this poll
steelies yes or no?
I would do what you like best, but what I'd be concerned about is that the hubcaps protect your steel studs that will attract rust/salt etc. If you run without your caps, I'd suggest that you use a lube on your stud's to protect then from rusting, & I would torque your lug nuts to spec. You don't want your `nuts to seize on the stud, especially if you have a flat tire & have to change
Good Luck
Good Luck
<img alt="Set Of 4 02 03 04 Chevy Malibu Police Center Caps Hubcaps 9593499" src="http://lh6.googleusercontent.com/public/SrFSalhYlAJ3TpZ3_jeZ-HKmGgafjQsbjoA1gljfgUc1Rwwi30pYyAy06pKAd8hjRt4mFbe i0AfRIW0niPEiC-szPNyjZgl_YLOtk6GYcrmbdRL6GLiZZoQDXzYVYIvFZpwIc83F KrMeRA4zrDCvM0mN0xWbOoZfijwg8jfl9p_t53qjmNjzFgWfLP Q0d-ReOW836PtWCeAUJh1_-WENI3b2vsJLfexShbAg=s90-c">
Set of 4 OEM 02 03 04 Chevy Malibu Police Center Caps Hubcaps 9593499 on eBay!
The ones Space posted should fit. You're looking for a 5 x 4.52 inch, or 5 x 115 mm bolt pattern. Look for caps that will fit a 2000's model year Impala, and you should be good.
I punched in "Impala police hubcaps" into ebay, and tons of results came up.
I still say try to look for at least the stock rims for the 5th gens, but if you really want the steel rims, definitely look for the center caps to go with it. Since you are a criminal justice major, it would look pretty cool too
