Proper Car Care + Auto Warranties : )
Old Feb 18, 2007 | 10:42 AM
Default Proper Car Care + Auto Warranties : )
[align=center][b]PROPER CAR CARE CAN EXTEND YOUR LIFE. IF YOU CARE
FOR YOUR CAR IT WILL TREAT YOU WELL, AND THUS
CAUSE LESS STRESS : ) LIVE LONGER TAKE CARE OF
YOUR MONTE CARLO [:-]
Aging Gracefully [/align]
How proper car care can extend the life and safety of your vehicle by Steve Temple
[align=center][/align]
Your car doesn't have to be a classic to have a lot of miles. "Advances in vehicle quality and engine technology have allowed American car owners to keep their vehicles on the road longer," says Eric Papacek, analytic consultant at R. L. Polk, the longest standing curator of automotive records in the United States. According to Mike Gingell, vice president of Polk's aftermarket division, consumers are keeping their vehicles longer for the first time since the mid-1990s. The median car age recorded in 2002 was 8.4 years, "the highest median-age since we began tracking the statistic in 1970."
At an average of 12,000 miles driven each year by most Americans, according to Popular Mechanics an 8.4-year old vehicle could have an odometer reading of approximately 100,000 miles. Therefore, even though advanced technology and better quality make the prospect of keeping and driving your vehicle — long after it's paid for — a justifiable one, once your vehicle reaches the 75,000-mile mark, it's time to take a more diligent approach toward its maintenance.
What specifically happens to a car as it ages and accumulates mileage? And more important, what can you do to slow down that process or even rejuvenate your vehicle? A preventative maintenance program of consistent car care — and a little common sense — can go a long way toward keeping your vehicle running strong and looking good well beyond 75,000 miles.
Parts of the Equation
Normal wear and tear is naturally going to occur over time, but keeping the undercarriage clean can help slow the process. Rubber bushings, for example, in the suspension are susceptible to deterioration from road grime. The rubber can wear from the oil and other contaminants under your vehicle, and the suspension components such as the swaybar bushings start to bind. When this happens, your vehicle's performance suffers. Rubber bushings that are cracked or eaten away may break down before the suspension can respond to a bumpy road, allowing for play or wobble.
Ball joints on older vehicles, for example, require regular lubing with a grease gun. Even though the ball joints on later-model cars are normally sealed, they still should be inspected for damage. In addition, misaligned or unbalanced wheels are the biggest causes of suspension problems. By the time your odometer hits the 100,000-mile mark, shocks and struts usually begin to show signs of age by excessive bouncing or body sway. Unusual or uneven tire wear is another indicator of possible suspension problems.
Other undercarriage components that often wear out over time include the hangers for exhaust systems. While the high nickel content in modern exhaust components helps to resist corrosion far better than in times past, if you live in the rust belt you'll need to examine the exhaust system at least twice a year.
Inspect and Check
[align=center][/align][center]Check for leaks in the brake hydraulic system and also in the transaxle or rear differential. Drips or stained seals are the often the best indicators of a possible malfunction. Giving them attention early may prolong the life of your vehicle and save on repair bills. Also check for leaks under the hood
Old Feb 18, 2007 | 12:36 PM
InTheIROC's Avatar
Default RE: Proper Car Care can Extend Your Life : )
The most miles I've seen on a car with the original powertrain is 460,000. It was a 1988 Volvo 240 and the thing was very, very clean. I would have guessed it had maybe 100,000 miles by looking at it, and that is only because of the age. It was a one owner car and had been serviced regularly at the dealership I worked for it's entire life. Quite impressive.
Old Feb 18, 2007 | 01:08 PM
DESS03's Avatar
we have an 82 chevy 3500 here at the house with a 6.5 turbo diesel that has almost 500k on it and my dad bought it brand new
Old Feb 18, 2007 | 01:24 PM
[align=center]
ORIGINAL: InTheIROC
[/align][align=center]Hi Members Andy & Richard, Thanks 4 your posts. That's amazing miles : )[/align][align=center]It just shows that it pays to take care of your ride, your baby.[/align][align=center]Treat it, like you love it.[/align][align=center][/align][align=center]Below article is from Motor Week Pat Goss[/align][align=center][/align]
Stop Interior Leaks
Pat Goss
Water leaks to the inside of the car can be dangerous! You've got to remember that mold and mildew in a confined space like the inside of a car can be very dangerous.
So, how do you go about finding those leaks? Well, you'll probably need an electronic leak detector such as we have here. This is a transmitter (right) that goes inside the car, then we have a receiver (left) for the outside of the car. Now, a leak could be coming from just about anyplace, could be in the cowl area, around the windshield wipers, maybe even around the outside mirror.
But what you do to find it is turn on the transmitter, put it inside the car in the general area where the problem is, close the car up, turn on the receiver, and as it comes close to the leak, it will start to leak because the radio waves come out where the water goes in. Pretty simple device.
In addition to that, there is another problem that people are faced with and a lot of it is through confusion. Many people have the idea that doors are sealed against water getting inside them. They are not! Water can go into the door; it runs through the door, and it runs out of small drain holes down in the bottom of the door, and that's fine until those drain holes clog up. When they do, the water builds up in the door until it reaches one of these lower holes and spills out into the inside of the car.
You can fix this yourself. We have a cut-away section of a door right here, and we're going to shine a light through one of these holes. You can see right here, with the light shining through it, and there are several of those on the bottom of the door.
All you have to do to clean the drain holes is take a piece of coat hanger, like we have here, wrap some tape around it so it can't go up into the door too far and hit some wires or damage anything, and you simply push it up and down into the hole, work it around in there to dislodge any dirt that may have accumulated over time, but don't look straight up at it while you're doing it because if there's any water in there you're going to get water right into your face.
Now, it's a very simple thing, it will keep the carpets dry, it will also keep the bottoms of the doors from rusting.
[align=center]
[hr]
[/align]
If you have a question or comment, write to me.
The address is MotorWeek, Owings Mills, MD, 21117.
Old Feb 18, 2007 | 09:13 PM
Bigg J's Avatar
ORIGINAL: InTheIROC
I knew a guy who is a mechanic with an old '78 Dodge van that had over 800K original miles on the clock. He'd bought it since new and kept it up ever since. He said that he had contacted Chrylser about it and they made an offer to buy it back from him when he hit 1Million miles.
I lost track of him, so not sure what happened to it.
Old Feb 18, 2007 | 09:44 PM
Mrrench's Avatar
91 Chevy Lumina
2dr Euro Sport
237,000 miles on her. Fuel pump, regulator and injectors were done at 225,000 miles other then tires and brakes...... NOTHING else was done.... and still running today.
Old Feb 19, 2007 | 09:53 AM
ORIGINAL: Mrrench
91 Chevy Lumina
2dr Euro Sport
Hi Michael -Mrrench- Is the Lumina yours ?
What engine is it ? 2.8L V-6 ?
__________________________________________________
Members, please add your post in reference to the ways that
you Extend the Life of your Monte Carlo.
or
Vehicles that have high miles without major overhaul.
Thanks, Space : )
Old Feb 19, 2007 | 01:06 PM
84 406's Avatar
We ave a 82 s-10 blazer at work that we run parts inwith 375000 on it
and I've been around this truck since it had 30,000 and the only thing
I know to have been replaced is the battery and alternator ........
well brakes and other "ware items" such as that
DINO KY
Old Feb 19, 2007 | 05:55 PM
Mrrench's Avatar
Yep
The Lumina is mine,
It has the 3.1 in her. Its the same engine that is in the 95 Monte Carlo which now has 115,000 on her.
Old Jul 15, 2007 | 09:42 AM
[align=center]FYI[/align][align=center]
Buying Extended Warranty Coverage
Y. Vazquez & MCF Reporter `Space
[hr]
No matter what we consumers buy, we expect it to fulfill our needs without problems. And, when a problem does arise, our refuge is usually the factory warranty. Now this is especially true with big items like a new car or truck. But how can you protect yourself when the factory warranty runs out? Our FYI Reporter Yolanda Vazquez looks into extended warranty coverage and the promises and pitfalls of this piece of mind protection. – John Davis
[hr]
It's a question most people ask themselves when they buy a new car. Should I purchase the extended warranty? Stephen Moss of Penn Subaru offers it to his customers to protect against unexpected repairs.
STEPHEN MOSS, BUSINESS MANAGER, PENN SUBARU: "It's optional to them, not something we beat them over the heads with, but we want to make sure that is something that is available to them."
RANDY DOWNS, VICE PRESIDENT, WARRANTY DIRECT: "It really depends on what a person is looking for: are you looking to cover just your major, big ticket coverage or are you the type of person who wants everything covered?"
These are just some of the basic questions a buyer should consider before purchasing an extended warranty.
How long will you keep the vehicle?
[ul][*]Most cars come with a manufacturer warranty, so if you plan on selling the car within three-five years, there's no reason to purchase an extended warranty. [/ul]
How much coverage do you want?
There are many different types and levels of coverage.
[ul][*]A bumper-to-bumper warranty offers the most comprehensive coverage. It usually includes everything except wear and tear items like brake rotors, tires, and upholstery. [*]A power train warranty is an affordable way to protect yourself against major repairs. It covers the engine, transmission and drive axles, about 25% of your vehicle. [*]A Named Component Warranty, will list the parts that are covered and only those parts will be covered. [/ul]
How much money are you willing to spend?
[ul][*]Several factors determine the price of an extended warranty, such as year, make, model and mileage. In general, prices range from $500 to $3,000, but that's not the bottom line. [/ul]
DOWNS: "There's always flexibility in negotiating the price of anything, especially when you're dealing directly with the company"
Who offers the best coverage?
[ul][*]Gone are the days where customers can only buy an extended warranty from a new car dealer. Credit unions, insurance companies, repair shops, and internet retailers, like Warranty Direct, all offer extended warranties. [/ul]
DOWNS: "I think with the advent of the internet people are finding a lot of services that they traditionally got at a car dealer; they're getting outside the car dealer."
At Warranty Direct's New York call center, more than a dozen reps field inquiries from prospective customers. When searching for a credible warranty company, be sure to check their history - have they been around a long time? Contact the Better Business Bureau to see if there are any complaints due to delinquent payment of claims and find out if the warranty is nationwide and will be accepted by dealers and independent repair shops.
Moss says his dealership will honor most extended warranties, but he recommends going with one backed by the new car manufacturer
MOSS: "Whenever you have manufacturer backed warranty, you know that it will be accepted at any of that manufacturer's dealerships throughout the country."
[b]And you don't have to get the e
Turbo2
Nov 24, 2014 07:35 PM
Timbo534
Jul 9, 2014 09:44 AM
myfirstbowtie
Aug 2, 2011 09:43 PM
mavrickf1613
Feb 21, 2009 03:24 PM
BLACK ATTACK
Feb 6, 2008 05:20 PM
