Lola is all fixed
Old Feb 11, 2013 | 07:03 PM
nitehawkjcb's Avatar
Never had a problem with the Monte keyhole freezing... And I keep between 30 and 35 PSI on my 16's
Old Feb 11, 2013 | 07:10 PM
I run my 235/50R18's at 32 psi.
Old Feb 11, 2013 | 07:15 PM
Originally Posted by tps221
true and do you guys ever have your drivers side lock freeze up when it gets cold after raining or is that just me not being able to turn the key
Buy some lock lube/deicer
Old Feb 11, 2013 | 07:20 PM
I had my Monte's driver door freeze shut after being dumb enough to wash it in the middle of winter. (a couple years ago) Had to use the passenger door. Then climb my 225 lb butt over the center console.
Old Feb 11, 2013 | 07:25 PM
Mike 00LS's Avatar
If you dry it good you won't have a problem. The last few weeks it's been a whopping high of 12, in the negatives with the wind chill and mine didn't freeze shut after washing. A little lithium grease on the weather stripping and thorough wiping you'll be good. At least it's almost back up into the 40s-50s this week.
Old Feb 11, 2013 | 07:26 PM
Red Nightmare's Avatar
Usually I keep my tires around 30-35 psi.
I've had my doors freeze shut in both my buick & bonneville. The bonneville was so stuck (both doors) i took a garden shovel, wedged it in the center of the doors to pry it open! (that car was falling apart anyway so I didn't care much anymore) The buick made me climb over the console...& there wasn't much room....
Old Feb 11, 2013 | 07:31 PM
Well, because it was winter, I went through the car wash to get the salt off. Made a stop at Home Depot shortly after. I think opening the door allowed the water to get between the rubber and the door frame. Then froze solid while I was in the store. Came back to one frozen solid door.
I was worried that I was going to rip the rubber seal. So I climbed in the passenger side, and drove around with the heater on high so I could get out normally.
Old Feb 11, 2013 | 07:32 PM
Dont think i've ever had a car door freeze shut to where i couldn't get it open.
Old Feb 11, 2013 | 07:34 PM
tps221's Avatar
its just the key lock and it was the freezing rain today that caused it ill give it a shot of wd40 tomorrow and adjust my psi seeing as my secon class for tomorrow got canceled and i i only have class 9:30-10:45
Old Feb 11, 2013 | 07:35 PM
tps221's Avatar
basically just wont let me turn left to unlock it. its not frozen shut
