Handy Helpers : )
[align=center][/align][align=center]
Handy Helpers
by Pat Goss of MotorWeek
Pat Goss and Tom Smith[/align]
I'm sure you're like me. You've been in the middle of a job and you say "gee I wish there was this little something that would help me out of a mess." Well maybe there are some things. Let's begin with products from HELP. Here we have a tail-lamp socket assembly that fits general motors pickup trucks and sport utility vehicles. In the past what you would have to do is buy the entire lamp assembly, which is expensive. This way you only buy the circuit board itself, saves a lot of money.
Here's something we see all the time in the repair shop: key fobs that break off right where the ring goes through them, what do you do? Well I've seen a lot of jury-rigs but here's something that makes a permanent and effective fix and it's real simple, again, from HELP, it's just a case that snaps around the existing fob and gives you a new connection.
Something else right here, if you looked at this you wouldn't have a clue what it was, but when you see what it does it makes a lot of sense. The diffuser in the dash for the air conditioner, lots of times they flop all over the place, they won't stay in position. Well, you take this little wedge and you push it in, of course you would push it all the way in, it can't be seen but it does restore the operation of the diffuser, no more matchbooks or anything like that stuffed into the dash.
Maybe you have an older car and maybe you want to keep that older car going for a long period of time but it doesn't have a lot of value and it maybe has a seized up or really noisy air conditioning compressor, can't really drive it cause the belt slips on it and all kinds of problems like that. Well, instead of replacing the compressor you may get one of these from HELP, this replaces the compressor, uses the same size pulley in the same position so you can use the original belt, and you don't have to lay out hundreds of dollars for a replacement compressor, pretty clever.
Now, 5.4 liter Ford V8 engines in pickups and sport utilities, they have a problem. You go to take the spark plugs out of the engine and...pop! The spark plug breaks off, you've got the top of the plug, the threads are down inside the cylinder head. Now presuming that these are the threads and that they're still down in the cylinder head, what do we do? Snap-On-Tools has the answer, and that is very simple: you take the tap that comes with the tool kit, the tap threads the inside of those remaining portions of the sparkplug. Now you take this tool, it screws into those threads that you just cut, then you tighten this top down which wedges everything together, you put a wrench right up here on the very tip of it and you turn those broken threads out of the cylinder head, and you're not spending $3 or $4 or $5,000 for new cylinder heads. What a savings that is.
[hr]
Product Information
* For more info on how to decipher the DOT code on your tire's sidewall and determine the month and year it was manufactured, try these handy sites:
http://www.nhtsa.dot.gov/cars/rules/.../brochure.html
http://www.steersj.ca/printables/2_TireBasics.pdf
[hr]
If you have a question or comment, write to me (Not `Space)or send me a DVD video of your question and you might see yourself on TV.
The address is MotorWeek, Owings Mills, MD, 21117[/align]
Handy Helpers
Now, 5.4 liter Ford V8 engines in pickups and sport utilities, they have a problem. You go to take the spark plugs out of the engine and...pop! The spark plug breaks off, you've got the top of the plug, the threads are down inside the cylinder head. Now presuming that these are the threads and that they're still down in the cylinder head, what do we do? Snap-On-Tools has the answer, and that is very simple: you take the tap that comes with the tool kit, the tap threads the inside of those remaining portions of the sparkplug. Now you take this tool, it screws into those threads that you just cut, then you tighten this top down which wedges everything together, you put a wrench right up here on the very tip of it and you turn those broken threads out of the cylinder head, and you're not spending $3 or $4 or $5,000 for new cylinder heads. What a savings that is. [hr]
Product Information
[hr]
[align=center][/size][/font]Members check out below media Vid`s[/align][align=center]I thought they may `help a member[/align][align=center][:-][/align][align=center]Click on below link source
[/color]
How-to video clinics. Watch and learn how to do it yourself![/align][align=center]
Battery Chargers Lawn Tractor: High | Low
Battery Chargers Motorcycle Battery: High | Low
Battery Chargers Heavy Duty: High | Low
Battery Chargers For All Needs: High | Low
Battery Chargers Analog vs Digital: High | Low
Battery Chargers 6V Battery Charging: High | Low
Jump Starter Starting a Vehicle: High | Low
Battery Clinics Maintenance: High | Low
Tricked Out Truck: High | Low
Lift Supports: High | Low
Washer Aim: High | Low
Washer Pump: High | Low
Total Charging System Care: High | Low
Tire Safety: High | Low
Jump Start: High | Low
Headlight Replacement: High | Low
Changing A Flat Tire: High | Low
Brake Basics: High | Low
Belts and Hoses: High | Low
Adjusting Mirrors: High | Low
Free Services: High | Low
Winter Prep: High | Low
Replacing A Fuel Pump: High | Low >Headlights and Taillights 101:
High
| Low
- New!>
Sensors 101 High | Low
Forgotten Filters High | Low
Off-Road Driving High | Low >
Wash & Wax High | Low >
ATV Maintenance High | Low >
Lawn Mower Maintenance High | Low
Hybrids & Alternate Fuel Vehicles: High | Low >Forgotten Filters: High
| Low
Timing Belts: High | Low
Tuner & Performance High | Low
AC & Cooling System 101 High | Low
Today's Tune Up: High | LowBelts and Hoses: High
| Low >
Attention to Detailing: High | Low Dream Garage: High
| Low
| Podcast>Today's Tune-up: High
| Low>
Suspension Upgrades: High | Low
Changing Brake Fluid: High | Low[/color] Total Charging System Care:
High
| Low
How To Save Gas: High | Low[/color][/color] Winter Prep:
High
| Low
| Podcast>
Water Pump Replacement: High | Low
Changing Disc Brakes: High | Low
Changing Drum Brakes: High | Low
Performance Exhaust: High | Low
Back to School Car Care: High | Low
Battery Basics: High | Low
All About Oil: High | Low Charging the AC System: High
| Low>
Installing Window Film: High | Low
Preparing to Tow: High | Low
Scratch & Dent Repair: High | Low
Shock & Strut Replacement: High | Low[/size][/font]
* iTunes required - download from Apple[/size]
Audio (mp3)>
Off Road
Car care for moms on the go
Cabin Air Filter
Hybrids Explained
[font=helvetica][size=3]Video [size=1](mp4)[/color]>
Battery Chargers: For All Needs
Battery Clinics: Maintainers
Battery Chargers: Heavy Duty
Battery Chargers: Motorcycle Battery
Battery Chargers: Analog vs Digital
Battery Chargers: Lawn Tractor
Tricked Out Truck
Lift Supports
Washer Aim
Washer Pump
Lift Supports
Sensors 101
Forgotten Filters
Off-Road Driving
Wash & Wax
ATV Maintenance
Hybrid & Alternative Fuel Vehicles
Winter Prep
Forgotten Filters
Tuner & Performance
Attention To Detailing
Suspension Upgrades
How To Save Gas
[color=#0000ff]Changing Disc Brakes
[color=#0000ff]Back to School Car Care
[color=#0000ff]Battery Basics
[color=#0000ff]All About Oil
[color=#0000ff]Scratch & Dent Repair
[color=#0000ff]Shock & Strut Replacement [/align][align=center][font=helvetica][color=black][color=#0000ff][color=#0000ff][color=#0000ff][color=#0000ff]
[font="times new roman"][size=5][color=#cc0000]Click on below link for source 2 view
[:-][/align][/align][align=center][color=#810081][size=1]http://www.advanceautoparts.com/engl...er_clinics.asp[/align]
[/color]
[/align][align=center]Battery Chargers Lawn Tractor: High | Low
High
| Low
- New!>
| Low
| Low >
| Low
| Low>
High
| Low
High
| Low
| Podcast>
| Low>
Audio (mp3)>
Off Road
Cabin Air Filter
Hybrids Explained
Tricked Out Truck
Lift Supports
Washer Aim
Washer Pump
Lift Supports
Sensors 101
Forgotten Filters
Off-Road Driving
Wash & Wax
ATV Maintenance
Winter Prep
Forgotten Filters
Tuner & Performance
Suspension Upgrades
How To Save Gas
