Been a while
Hey all, been a while since I checked in here. Been busy with work and the holidays along with getting the build planned and started on the Vette! Figured I would fill you guys in a little on the new toy though.
I have swapped to black wheels with nitto nt05r's on the vacl, blacked out all the corner markers, painted the fender spats carbon flash to match the splitter. I still want to tint the tailights and then the exterior is complete. I have also got the itch to add some more hp (go figure) lol. So with that said this is the build that is underway. Heat exchanger, ice tank, ported blower with 103mm snout, 103mm tb, stage 3 PD cam kit, weapon x valve covers, headers, direct port 100 shot nitrous with a dedicated fuel system for the nitrous (c16) also direct port meth will be sprayed and the car will be fed with E85. Goals are 750whp without spray and 900 on the giggle gas. Trying to get a low 9sec pass out of her in the 1/4 :) We have also added some more hp to the cts-v. We went with a set of id1300's and increased the boost a bit more. It's not sitting at 724whp on a mustang Dyno and the car picks up almost 2psi boost on the street so we estimate power on the street around 760-780whp. This past fall we were able to get the car run 10.2@138mph. with a better launch it should be in the high 9's. I hope everyone is doing well here, happy holidays to you all! |
