Anyone know of an active welding forum?
Or if anyone here has some expertise on the subject.. I could really use some help with a few things..
First; my Miller took a sht on me so I am borrowing a friends generic brand welder.. You can find them with all different brands but ultimately its the same one as here sold to companies for said company to brand themselves.. Does that make sense? Sorry if not.. Some examples: http://i68.tinypic.com/1192ck0.jpg http://i66.tinypic.com/bbgc5.jpg http://i64.tinypic.com/2ewduhk.jpg Anyway, I cannot find ANY useful kind of user manual and he said the supplied one was worthless also. So you got "1" "2" On one switch. "Hi" "Low" on another. Then you have your feed speed on the dial.. I ASSUME the dial is just a fine tune after you set the "1-2" Switch for hi and low speed, NOPE.. "Hi-Low" switch doesnt change feed speed.. The dial is all that regulates wire feed.. Them two switches... Do the same exact thing, crank up the amperage. Ive never used or seen a welder that works like this.. Can anyone give me any insight on this?? Next issue is my wire.. My Miller is able to burn flux-core which is what this welder can ONLY use.. I burn the flux-core when I dont wanna lug around a big tank of argon, but thats beside the point. When going to load up the wire in this "mig-130" I noticed my normal flux-core said "carbon steel". I have always used mild steel (so I think) and dont see a difference other than this carbon steel wants to kinda.. Elongate the puddle whereas leaving the machine at the same settings used for carbon steel, causes the mild steel to build up probably 3-4 times more than it penetrates. This is turning into a headache cause I just wanna flip the switch and arc up. Instead im popping, splattering, sticking, and its also been tripping my breaker.. Thats really crazy cause it calls for a 20amp breaker and its running on a 50Amp so... I GREATLY appreciate anyone who endured this life story and hope someone can give me some advice. Thanks for anything anyone might have. EDIT: The switch I called "Hi-Low" is actually "Min-Max".. |
Here is a link to a search on google there are several to check out? :thumbsup:
https://www.google.com/?gws_rd=ssl#q...=1496424988499 |
(Post 703679)
https://www.google.com/?gws_rd=ssl#q...=1496424988499 Anyhow, I ended up speaking with someone on a Miller forum who gave me the great suggestion to upgrade my lines/ run a dedicated 75amp line to the garage.. He also gave me great info about the main board and switch controls.. Thanks tho... |
