`505-HP Z06 Powered Chevy Camaro : )
[align=center]
First Drive: Chevy Camaro Z06 [/align][align=center][/align][align=center][/align] Throwing Gears in a 505-hp Z06-Powered Chevy Camaro Date Posted by `Space: 06-07-07 This 1999 Chevrolet Z28 Camaro is no ordinary used car. It's a freaking street monster; a snarling, mean mother of a street racer that will chew you up and spit you out if you have the temerity to challenge it at a stoplight. It's powered by a GM Performance Parts (GMPP) LS7 crate motor packing 505 (or more) horsepower, the same engine you'll find under the hood of a Z06 Corvette. In fact, GM Performance Parts built this car because it wants the world to know that the all-aluminum small-block V8 is for sale at any GM dealer's parts counter (or even online). The other reason the motorheads at GMPP built this beast is because the coming'09 Camaro[b] will probably have an SS edition available, which will be powered by this same engine right off the showroom floor. The Doctor Is in the House Dr. Jamie Meyer, the father of this flat-black brute, is the product integration manager at GM Performance Parts. We have no idea what a product integration manager is, except that Meyer is a reincarnated hot-rodder/muscle car street rat from the '60s who was reborn into today's corporate world, and gets to dream up and build all these really hot muscle machine packages out of GM Performance Parts. Is that a great job or what? You can tell Meyer is thoroughly enjoying himself. The LS7 is part number 17802397 and will literally drop into the engine compartment of any 1982-2002 Camaro — or for that matter, any small-block-powered Camaro back to 1967. You can even use the same motor mounts. Now this Camaro demonstrator packs mind-blowing power that dates back to the big-block 427 and 454 engines of Chevy's glorious past. It screams to a 7,200 rpm redline (patrolled by a rev limiter) and peels back your eyelids every time you nudge the throttle. Because this car was going to be a test mule both for the GMPP engineers and a bunch of crazed auto journalists, Meyer decided to beef up the already impressive engine. LS7 Plus The GMPP engineers were able to keep the stock LS7 oil pan, but that meant they would have to accommodate for the LS7's dry-sump oiling system. The battery was placed in the trunk, and 2 inches were sectioned out of the stock oil tank. The new oil tank now resides in the position of the vacated battery. A BMR cradle, or K-member, was used to physically hold the LS7 in position with standard LS engine mounts. In front the LS7 is dressed with a Z06 Corvette air-conditioning compressor and an ATI damper/balancer for clearance, and to adapt an F-body accessory drive. The stock 58x reluctor wheel remains. The Camaro's original stock LS1 350 air intake (with SS hood scoop) was retained with slight modifications to adapt it to the LS7 throttle body. The engineers used a custom GM Performance Parts wiring harness and their own custom calibrations fo |
RE: `505-HP Z06 Powered Chevy Camaro : )
Can you say....SLEEEEEEPER!!!
