Max tire width with stock wheeltubs
I would like to know the maximum tire width with the stock wheeltubs for a 1986 Monte Carlo LS. How difficult is it to tub and will aftermarket wheeltubs be needed for a 10 inch tire or can I use the stock ones?
Originally Posted by Todd919
(Post 314865)
i want to know as well, i want to put on 22" in the rear and 20's in the front 84' mont carlo with a 1"drop
Originally Posted by aamer415
(Post 318596)
22''x 8.5'' rim/ tires 245/30/22 255/30/22 22''x 9.5'' rim/ tires 265/35/22 *22''x 10'' thru 11'' on a 295/25/22 with the right offset of maybe (35+) and some mods (rolling the lip) on the upper rear quarters. the front you can go as big as 22''x9.5'' with 245/30/22, 255/30/22 without issues. A 265/*35/22 (*35 may be to tall with that width)with some mods, so you have plenty of room for a 20'' wheel. Dont just take my word always take your car down to the wheel shop so they can retro fit many sizes of wheel and tire setup to get the best fit possible. I was thinking of a 20''x 9'' on a 245/30/20 for the front because of potential fender rubbing issues. 22''x 9.5'' on a 265/35/22 tires. Instead I came out with a 22''x 9.5'' with a 245/30/22 up front with no mods. the rear was a whopping 22''x 11'' on a 295/25/22 on the rear. We roll the upper lip which took less than 10 mins to do each side with a hand circular saw and rubber mallot. I also have 2'' drop spring in the front to level out the look. |
Thanks you so much JW!!! That is perfect info that I was looking for!!!
(Post 318974)
do you know all this for expierience? did you have a 4th Gen. Monte?
(Post 319626)
cool, thanks!!!
| All times are GMT -5. The time now is 02:43 AM. |
