Easiest way to get to the change plugs on an 04 monty sc'ss
Old Aug 15, 2008 | 09:26 PM
bowtiebully's Avatar
Default Easiest way to get to the change plugs on an 04 monty sc'ss
Sup fellas what the easiest way to get to the plugs on the back side im about to do a tune up on it ,and what do you think about bosch wires good or not so good
Old Aug 15, 2008 | 09:29 PM
Default RE: Easiest way to get to the change plugs on an 04 monty sc'ss
lol ooops i meant whats the easiest way to get to the back spark plugs ..
Old Aug 15, 2008 | 09:37 PM
RickCoMatic's Avatar
You have to undo the two front Motor Mounts.
Attach a Ratchet Strap to the Engine Pulling Bracket and anchor the other end under the car using a old blanket to protect the finish.
Take-up the slack until you rotate the Engine as far forward as it will go.
Now, there's just enough room between the Firewall and the Block to spin wrenches.
I changes my wires to Bosch.
They're doing the job ... just fine!
Old Aug 15, 2008 | 09:44 PM
Thanks rick but to be honest that sounds complicated ...at skill level with 10 being that highest im about a 4 is there another way .
Old Aug 16, 2008 | 11:15 AM
mrl390's Avatar
Yes there is another way. Get someone else to do it. The way rick said is the easiest way to do it.
Old Aug 16, 2008 | 06:52 PM
My skill level is high. I have all the tools I need or get what's needed to do a job. After I got clued-in about the Ratchet Strap and tilting the Engine forward; I figured the job was going to be a Piece-O-Cake.
No dice.
It took me three days to get three Spark Plugs changed on the Firewall side of a 3400 Block.
I couldn't get the Plug Wire Boots to come off the Plugs. The wouldn't budge. I had to pull-out all the stops and fabricate a method to attach a section of nylon line to the Boot and pry the dad-blamed thing off them Plugs.
I only ruined one Boot.
Then the Plugs wouldn't come-out. I went from a 3/8ths Ratchet and Plug Socket to a 1/2 Inch Pry Bar to bust those Original Factory Plugs loose.
I had to fight with each one.
By the time I got done changing-out six Plugs and a whole set of wires; it was 3-Days of improvising and swearing and cursing and wondering why it was so hard for me to accomplish one of the simplest maintenance chores there is.
Get yourself a Ratchet Strap.
Stop-off at Salvation Army and get a few old pillows and a blanket.
After you get the Mill pulled forward away from the Firewall ... put the pillows right on top of the engine and spread the blanket out so you can lay right on top of the engine comfortably.
It's going to be a long day in camp ... doing the Rear Plugs and Wires.
You might as well make yourself comfortable!
Old Aug 16, 2008 | 07:41 PM
mrl390's Avatar
Jeez. And I thought doing my back plugs was hard. I have to pull the entire UIM to get to the back and unbolt the throttle body runner and the coil pack bracket. Even then the rachet barely fits and thesocket doesnt want to come out of the hole. I had to tape it to the extention. It didnt take me nearly as long tho. Doing it 3 times to get the plug gap right is what really took the most time. [sm=smiley21.gif]
silver1
15
Sep 17, 2016 05:15 PM
v2evo
May 5, 2011 04:39 PM
jhornekm
Sep 19, 2010 11:00 PM
monte carlo 3831
Jul 9, 2009 09:03 PM
JOJOECARLO
Jul 6, 2008 10:31 PM
