braking noise idiot lights appear
Old Jan 24, 2015 | 04:20 PM
billyb's Avatar
Default braking noise idiot lights appear
Wen I step on brake makes a weird noise multiple lights appear on dash along with service traction and traction off light.
Last edited by billyb; Jan 24, 2015 at 04:23 PM. Reason: confused of problem would like to resolve issue
Old Jan 25, 2015 | 09:45 AM
ohara's Avatar
The weird noise your hearing is more than likely your abs kicking in.
The traction control lights is more than likely related to the following
Wheel Speed Sensor
Wires connected to the sensor that have rotted out along the frame, common occurrence in our cars.
Need to replace the wheel hub, this will give you a new sensor.
Check the codes that come up when the light goes on, on the dash, you have to have a reader that reads abs codes as most cheaper ones don't so you may have to go to a dealer or garage and have them read it to find out which sensor is causing the problem.
Welcome to the forum
Old Jan 25, 2015 | 10:57 AM
How many miles on it?
Maybe its time to get the brakes relined?
Pads and rotors etc...
Malcolm Fay
Feb 17, 2015 04:25 PM
Tavi07SS
Aug 16, 2010 12:20 AM
ffriccio
Jul 27, 2007 09:14 AM
steptoe
Oct 6, 2006 12:50 AM
rshook
Mar 3, 2005 09:45 PM
