-   -   Wiring Harness for O2 Sensors (https://montecarloforum.com/forum/monte-carlo-repair-help-8/wiring-harness-o2-sensors-34940/)
myronprescott Mar 15, 2012 12:35 AM
I believe this may be my problem with my check engine light because I've replaced both sensors (twice) & I went to the dealer & the codes I'm getting are p0141, p0131, & p0135 all electrical related.
Does anyone have any experience replacing this & how much it would cost? BTW it's for a 07 MC LS 3.5 Flex Fuel Engine
03SSLE Mar 15, 2012 08:13 AM
Did you replace the sensors with AC Delco units? Are the replacement sensors of the heated variety? These vehicles can be picky when it comes to their sensors and a lot of times replacing them with a brand other than AC Delco will set the CEL because the sensor isn't within the parameters of the original unit.
ChibiBlackSheep Mar 15, 2012 08:27 AM
What brand sensors did you use? They seem to be related to the heating element. Did you get a heated sensor?
Also make sure you don't have any intake leaks, or anything causing you to run too rich, that could affect your sensors too
*edit* had tab open for some time, and see that Mike above me said almost the same thing lol
myronprescott Mar 16, 2012 09:45 PM
Yea I just put heated AC Delco sensors on there, but I do have a small oil leak do you think that could be causing it to run lean, because i do have hesitation while driving still
myronprescott Mar 30, 2012 07:31 PM
Finally got my problem solved turns out I had a loose connection to my fuse box. Hopes this helps someone in the future.
