97 z34 no power
Old 10-28-2011, 02:49 PM
Code Red Monte's Avatar
Default 97 z34 no power
yo so i bought a 97 z34 for 1800 bucks last week and now after i have cleared the DTC codes and found some massive vacuam leaks, now the car has no power after 3 grand at wot, the DTC codes it was throwing was cylender 5 missfire, 02 sensor low voltage, and engine cooland temp sensor fault, well the engine colant temp fault was due to the plug being not pluged into the block, so got that taking care of and cleared hte faults, but now it acts like the leans out huge now at around 3k, im thinking a cat or a 02 fault. but fiqured id ask here. thanks
Old 10-28-2011, 04:01 PM
mrl390's Avatar
I would lean towards the cat. How many miles on the car?
Old 10-28-2011, 04:17 PM
120k, but i did notice that today when i did a scan on it, i was seeing no knock at wot, and the 02 was reading 0 volts over 3500 rpms.
Old 10-31-2011, 11:36 AM
mrl390's Avatar
Try the O2 sensor first, it will be cheaper than replacing the cat. If that doesnt fix the problem at least you can rule the O2 sensor out.
chrismm
05-16-2014 08:08 AM
tbmaniacal
11-29-2010 02:09 AM
Cyst3m
09-17-2010 04:08 AM
jibb3r
08-03-2009 05:22 PM
Quick Reply: 97 z34 no power
