6th Gen ('00-'05): Will turn over but not start
Old Mar 24, 2015 | 06:26 PM
Jhensel33's Avatar
Default Will turn over but not start
Have a 2000 ss..engine will turn over but not start..3 times while driving it just died, shifter to neutral and it started right back up...last time I made it home and now it won't restart..replaced fuel pump, but not sure where to go from here...any help?..
Old Mar 24, 2015 | 09:59 PM
nitehawkjcb's Avatar
First of all - are there any check engine codes? If not...
Unplug the MAF sensor and try to start it. If it starts, there's the problem most likely. If still no start, plug the MAF back in and check for fuel pressure. If fuel pressure is good, then it is (probably) the crank sensor, ignition control module, or possibly ignition switch.
If it doesn't even try to turn over, that's either a starter issue or passlock issue.
Just my .02
schoentges16
Feb 27, 2021 06:43 AM
BrandonStebing
Jul 25, 2014 11:03 AM
z34phoenix
Mar 10, 2014 11:32 AM
Adam Metz
Nov 8, 2013 07:09 AM
jbartram
Apr 9, 2012 03:41 PM
