where is the LOW side?
Hi Kids, I need a shot of freon for the A/C where do u put it in? Where is the low side and how much do u put in ? I dont need much. the air comming out is right at 55` but i want it just a tad bit colder.
I hope the below link helps you stay cool...Good Luck..
If it doesn't help, check back to see what our expert tech's post & also check out MCF search engine..
How to Install Freon in a Monte Carlo | eHow.com
Click above link
Click above link
Typically ac is good for 40 degrees lower than ambient temp. I wouldn't go putting Freon in if you don't need it. You can do a good amount of damage.
With that said, it's the port on the rear of the engine.
low side
yesterday in St Louis it was 107` a/c was on for about 1 hr 10 min @ 55` and i was driving the car on I 64 going to Scott AFB.
Hi Dave, thanks for your update..Was your a/c working ?
Was it cool enough 4 -Sure...Did you read the infor in below link & did it help ? Thanks member's for posting your help
Click above link
Good Luck `Dave & I hope U stay cool driving your Monte
Click above link
low side
Click above link
Click above link
If the ambient temp was 107° then your A/C is working perfectly fine putting out air at 55°. About the only thing you can do is make sure you have it set for recirculated air and not outside air.
