Changing Lightbulbs?
Old 06-28-2010, 03:41 PM
theundertaker's Avatar
Default Changing Lightbulbs?
Does anybody have instructions on how to change the Headlight bulbs on the 6th gen? Also, on ebay they have HID lights like this http://cgi.ebay.com/ebaymotors/Rav4-...ht_2440wt_1165
Would these just fit right in, in place of the originals?
thanks!
Old 06-29-2010, 11:29 AM
I wouldn't mess with HID Lights, they are illegal when not in a projector. (no they don't make projectors for our cars)
Changing your lights is very easy.
Pop the hood, and look at the headlight assembly. There are 2 plastic clips (white) that you pull straight up, and then slide them out and off (you'll see) Then you disconnect the power plug (just lift the tab and pull out) and then the whole headlight assembly will be in your hands.
Using gloves!!!!!!!! take the plastic backs off, and the bulbs sockets will be visible. Just twist 45° and pull out, replace plug, reverse to put back in.
Old 06-29-2010, 11:33 AM
Montelicious's Avatar
Yeah! Why don't they!
Monstercarlo
03-18-2009 02:26 PM
ralphtrent
07-25-2007 07:26 AM
orthokneepa
08-17-2006 08:30 AM
Pjw350
03-20-2006 05:33 AM
ralphtrent
10-05-2005 03:35 PM
Quick Reply: Changing Lightbulbs?
