vibration in the steering column
I have an 02 with 200,000 and I have noticed a VERY slight bit of wear in the steering column. I thought it might be because of the tilt mechanism. It feels like a bushing/bearing or joint is getting sloppy.
I've been told that if I pull the steering wheel off there are a couple bolts inside the column that probably need to be tightened??? Thanks, Gib |
