U-Bend Deleted, lowered shift shock...
Did anyone else notice that after the U-Bend is deleted it seems like the shift shock from the transmission is reduced upon 1-2 gear when starting off from a stop? I believe I noticed this more than the added HP. The car seems to flow more evenly now than before. Did you guys notice it too?
Also, when would it be recommended to get the tranny hot flushed? At what mileage is it ideal. Thanks!! |
RE: U-Bend Deleted, lowered shift shock...
The tranny subject has been kicked around here a few times. Opinions differ from 30K miles to 75K miles. I don't see how a more frequent flush could hurt it. Mine in coming up on 22K miles from new. I am thinking I will have mine done at 30K-35K miles simply because of how tempermental these trannys are. Want to keep it happy!!
I am pleased to hear about your experience with the U-bend delete concerning the transmission. |
they claim at 50.000 is when your suposed to change filters and fluids. I will be doing mine for the second time here shortly but that is becuse it is time for a up grade.
Well mines is at 24K, I was thinking of getting it done at 30K.
this may be a stupid question but what type of fluid would you use and filter can you get this at a local auto parts store
The dipstick should read exactly what the car takes. I believe on ours it's regular Dextron III, but do yourself the favor and check first. Also, you could check the manual or with your local dealership.
The filter you should be able to get at any autoparts store, though they may have to order it. |
I've always flushed mine @ 30K..... Anything past that drop the pan....
i will be droping the pan and as far as oil im thinking of trying the roayl puprle tha thtey sell here but it is 10.00 a qt. Man that stuff if high LOL
But hey at least i know my third child will be in good shape. just need to do the plug wires and a belt before the snow flies and i will feel so much better. That and it is time for new tires once a gain. (ra the hell out of the ones i have now. but more for summer then snow) |
| All times are GMT -5. The time now is 04:13 AM. |
