6th Gen ('00-'05): Trying to locate part....
Trying to locate the vacuum fitting that is on the front side of the throttle body, Its a rubber fitting that slides on to a fitting on the throttle body that reduces down to two hard plastic black vacuum lines. The hose fitting / adapter is less then 2inches long. Searched GM Parts Direct but nothing pops up. Any help would be appreciated. Thanks and Happy New Year!!!
https://www.rockauto.com/en/catalog/...harged,1424056
