Trans cooler lines
I need to replace the trans cooler lines on my 2002 Monte Carlo but they do not have the normal flare fittings on them. How do I remove them from the trans and the radiator?
RE: Trans cooler lines
Here is the procedure for trans. cooler pipe replacement...........
[hr] Transmission Fluid Cooler Hose/Pipe Replacement Removal Procedure [ol] http://service.gm.com/engif/000/000/104/104739.gif http://service.gm.com/tif.gif Important Perform the following procedure when removing the retaining rings and cooler lines from the quick connect fittings located on the radiator and/or the transmission. Pull the plastic cap back from the quick connect fitting and down along the cooler line about 5cm (2in). Using a bent-tip screwdriver, pull on one of the open ends of the retaining ring in order to rotate the retaining ring around the quick connect fitting until the retaining ring is out of position and can be completely removed. Remove the retaining ring from the quick connect fitting. Discard the retaining ring. http://service.gm.com/engif/000/000/104/104740.gif http://service.gm.com/tif.gif Pull the cooler line straight out from the quick connect fitting. [/ol] Installation Procedure [ol] Important [*]Do not reuse any of the existing oil lines or oil line fittings if there is excessive corrosion.[*]Do not reuse any of the existing retaining rings that were removed from the existing quick connect fittings. Install new retaining rings.[*]Ensure the following procedures are performed when installing the new retaining rings onto the fittings. [/ul] Install a new retaining ring into the quick connect fitting using the following procedure: http://service.gm.com/engif/000/000/104/104743.gif http://service.gm.com/tif.gif Hook one of the open ends of the retaining ring in one of the slots in the quick connect fitting. http://service.gm.com/engif/000/000/104/104746.gif http://service.gm.com/tif.gif Rotate the retaining ring around the fitting until the retaining ring is positioned with all three ears through the three slots on the fitting. http://service.gm.com/engif/000/000/104/104741.gif http://service.gm.com/tif.gif Do not install the new retaining ring onto the fitting by pushing the retaining ring. http://service.gm.com/engif/000/000/104/104664.gif http://service.gm.com/tif.gif Ensure that the three retaining ring ears are seen from inside the fitting and that the retaining ring moves freely in the fitting slots. http://service.gm.com/engif/000/000/104/104752.gif http://service.gm.com/tif.gif Install the cooler line into the quick connect fitting. Insert the cooler line end into the quick connect fitting until a click is either heard or felt. http://service.gm.com/engif/000/000/104/104750.gif http://service.gm.com/tif.gif Do not use the plastic cap on the cooler line in order to install the cooler line into the fitting. Pull back sharply on the cooler line in order to ensure that the cooler line is fastened into the quick connect fitting. http://service.gm.com/engif/000/000/104/104753.gif http://service.gm.com/tif.gif [color=brown] Important Do not manually d |
