Strong Vibration
Got a question for you guys... When I accelerate and get past about 30 mph the car to starts to shake and vibrate. If I let off the gas i stops. Does anyone have any idea what could be causing this? CV Joints, motor mounts, etc??
At that speed it's a cv joint, transmission, or a very bad ball joint or tie rod. I would lean towards a cv or trans though. Does the vibration go away at higher speeds? Or worsen? Could be a bent rim also or separated tire.
