It Starts Then wouldn't start...Now won't start At ALL!! Please Help.
Well, I got in my 97' and yeah it wouldn't turn over....The dash cluster and everything comes on but idk. I don't think its the battery because I didn't even here it click like the battery was dead..... I'm no mechanic by any means believe me. I popped the hood and have giggled the ignition relay and it would crank up.....Do I need to replace the IGNITION RELAY or is it somethin else. Any help would be greatlyappreciated.
Thanks. |
RE: It Starts Then wouldn't start...Now won't start At ALL!! Please Help.
x
Check out this post (https://montecarloforum.com/m_45667/..._/tm.htm#45667). I had a problem like yours, not sure if it is the same, but check the post to see if anything sounds familiar.
I'm no mechanic either but it sounds like the same problem my friend had with his 80 mc it cranked but wouldn't start turned out to be the ignition coil went bad replaced it and it started right up
could be the VATS system
VATS usually reports a Security CEL. It could simply be the key though. Do you have a spare set of keys to try?
| All times are GMT -5. The time now is 12:46 AM. |
