Starter problems
HI guys, hopefully I gave come to the right place. i have replaced my starter and it is now constantly running. I can't seem to figure out what is going on. i have change the relay with the rear defroster one with no change. the only thing that I have found so far that does make sense ( and maybe this is where the problem is) I tried pulling the ignition fuse while the car was running and the car stopped running which maybe normal I don't know? When I was puttting the fuse back in the key was still in the run position and I could hear the actuator activating as I was doing this. So my question is, is this a grounding issue igntion swith issues short somewhere or something completely different any help would be greatly appreciated. Thanks Todd 2007 Monte LS 3.5 |
