specific vibration
my 02ss has developed a vibration only when the left side is under load,(heavy right turn) and under throttle.
let of the gas :no vibration. the more throttle while side is loaded, the more vibration. straight line,hard left turn(no matter how hard, or how muchthrottle) no vibration. i think its the wheel bearing. any other ideas? thanks |
RE: specific vibration
Might be CV Joint going bad. Happened on the `97LS and replaced both driveshafts for good measure.
dotn do the heavy right turn under throttel?
but actually i had one do this in a old car and it was the berring. i think even if it wasetn and i had to do the front shafts i would change the berrings while i did it as the whole front end is damed near apart anyway |
fixed!!!!!!
driverside cv axle vibration gone wooo-hoooo pain inthe blankto by yourself but not impossible thanks for your help. if there is ever another monte madness i'll see you all again. thanks, BOSTON |
